Текущее время: 07 май 2026 13:38
 Заголовок сообщения: Toshiba Sat. A300 external monitor problem
СообщениеДобавлено: 23 сен 2009 14:36
I have Toshiba Satellite A300 and external monitor doesn't work. When I connect external monitor computer recognise it, but no picture on it. Try all solutions about setup (in BIOS and with Display setup...).
I suspect on VGA driver or some kind passive protection components etc. varistors (it used with projector for presentations).
I have no any kind of schematics of that output VGA port.
Have you any idea?
Best regards, and sorry for my english (you can wrote me in russian, I am learning it on your forum ;).
СообщениеДобавлено: 23 сен 2009 14:46
А как реагирует функциональную кнопку переключения внешний-встроенный при подключенном внешнем мониторе ?
СообщениеДобавлено: 23 сен 2009 14:54
Есть какая-нибудь реакци на нажатие Fn+F5?
СообщениеДобавлено: 23 сен 2009 16:52
Thank's for fast reply,
yes that Fn+F5 not so perfect ("flickering"), but work's. With Ctrl+Alt+F12 I have done various setup but still the same, no picture on external monitor. I have done more test's, etc. on boot sequence nothing on ex.screen, also try with live Ubuntu, and some others bootable software and still nothing change.
I have uninstalled and deleted graphics driver, and installed new...
Didn't try to update bios because I think that is hardware problem.Not so shure???
But, right now I saw something new: in devices manger/display adapters/ second/ (on VGA output-port is external monitor connected) - I have "warning" that "this device is not working properly".
The problem code is 31, and more details is:
Error: Pnp problem code 0000001F.
And I have forgotten to say that in that notebook is Vista32, and graphics is Mobile Intel(R) 4 Series Express Chipset Family.
СообщениеДобавлено: 23 сен 2009 17:05
It is wide range problem "31" :"The device is not working properly because Windows cannot load the drivers required for this device".
I think there is comunnication hardware problem, or graphics adapter memory problem.
СообщениеДобавлено: 23 сен 2009 18:05
what's videochip in this laptop? tell exact part number and config of your unit(expecially, it is interesting, if this laptop has nvidia videochip).
СообщениеДобавлено: 23 сен 2009 18:55
Do you try to connect your laptop with normal monitor or LCD TV?
СообщениеДобавлено: 24 сен 2009 01:26
It has Intel AC82GL40/SLB95 (graphic/north bridge).
I try with external some CRT's monitors (2 different type), and with some LCD display connected to VGA port, but no picture on any of them.
I saw that it has problems when installing properthy graphics driver, sometimes "warnings", sometimes no errors after installation.
I think that there is problem bad soldering bumps on 82GL40.
I would be happy if I'm wrong.
СообщениеДобавлено: 24 сен 2009 02:12
And as usuall, in this job always problems with marking code on specific devices... Driver/buffer for this VGA output port is 8 pin. IC (U604 on this Toshiba A 300 m.board) marked as "C26".
It is 74AHCT2G126DP, datsheet is here http://www.nxp.com/acrobat_download/datasheets/74AHC_AHCT2G126_4.pdf
СообщениеДобавлено: 24 сен 2009 13:44
did you try to connect come other monitor? and the last one try: disconnect LCD-module from motherboard, and turn on the laptop. if you see the picture on external monitor - the problem is in drivers or some other software issues. and if you don't - this is hardware problem. and yes, this model(sat a300) has this problem(dying of northbridge).
 Заголовок сообщения: Re: Toshiba Sat. A300 external monitor problem
СообщениеДобавлено: 05 окт 2011 18:53
This is few years old topic, but I see that I forgot to say that I have solved this problem with that buffer "C26" (U604), or 74AHCT2G126DP.
I have found it on some old Nokia mobile phone like 6150 etc...
Sorry for the late response.
