Текущее время: 18 май 2026 15:23
 Заголовок сообщения: compaq presario 2200 intel
СообщениеДобавлено: 24 дек 2008 23:15
stuck in reset mode any idea i have changed the southbridge .the power comes on but on display
repairs of laptops and selling of components
СообщениеДобавлено: 25 дек 2008 13:44
north bridge. reball or change.
хуже обезъяны с гранатой может быть только неграмотный инженер с паяльником,феном и программатором...
skype - Realsenshi
СообщениеДобавлено: 25 дек 2008 14:59
how did you found that the unit in reset mode? do you have the POST card? anyway, afaik, these models have known typical issue, it's broken bios image.
 Заголовок сообщения: re 2200
СообщениеДобавлено: 25 дек 2008 15:24
well you right i have a post card and it says reset i changed the southbridge and north but same problem i also reprogrammed the bios image from the net still same error.also i have another board which it rad the ram but gives no display the frame hangs after a while.does anyone have a good dump of bios.can it be the issue with the ram slot resistor or the terminator.
Зарегистрированные пользователи: Google [Bot], servis67, Yandex [Bot]
