Текущее время: 18 май 2026 15:22
 Заголовок сообщения: max1772 compaq v2000
СообщениеДобавлено: 11 июл 2008 23:34
charging problem i changed the max1772 multichem ic alsomosfet for the batt but still no charge micom is pc97551-vpc
repairs of laptops and selling of components
СообщениеДобавлено: 15 июл 2008 13:52
the problem can be conected with faulty battery. did you check this laptop with good battery(which you know, that it's good)?
 Заголовок сообщения: re max1772
СообщениеДобавлено: 31 дек 2008 11:36
i have another problem with charging changed max1772 the problem is the first point of batt is giving 18V without battery .I have also put new battery but same problem .there is an ic max1992 is it also used for charging.
regards,
Зарегистрированные пользователи: Google [Bot], servis67, Yandex [Bot]
