Текущее время: 18 май 2026 11:58
 Заголовок сообщения: compaq presario 2200 power/reset
СообщениеДобавлено: 28 фев 2009 23:06
i have this compaq 2200 the machine works all fine but when you shut it down and try to power it again does not power on if we press the reset button or remove the ac adapter and plug it again then it works fine the display and everything works while the problem is only when shutdown to reset it manually to power on everytime.what i noticed is that the signal sus_5v does not go to logic low.does anyone know what this can be .
I have another machine same model in this no display with 1.4 cpus if i use a 1.5ghz cpu it is okay or 1.73 works well but sometimes you have to power 2 times for display.i changed the max1907a but same problem
repairs of laptops and selling of components
