Текущее время: 02 май 2026 20:19
 Заголовок сообщения: Working Dump for Toshiba C855-1KD
СообщениеДобавлено: 27 фев 2015 19:56
Hi colleagues,
need a working dump for Toshiba C855-1KD
Platform: PLF / PLR / CSF / CSR / DSC MB REV. 2.1-
 Заголовок сообщения: Re: Working Dump for Toshiba C855-1KD
СообщениеДобавлено: 27 фев 2015 20:43
ACPI Flash BIOS version 6.70 for Satellite C855/L855/S855
http://support.toshiba.com/support/driv ... xt=3619590
Hello. Learned the way of the regular installer. Before flashing please save the original dump.
http://rghost.ru/6tpd7Y2BM
СообщениеДобавлено: 27 фев 2015 21:32
Wish to clarify :
Lap came with display fail issue (internal and external)!
All voltages are checked ok, but TXLOUT signals are absent.
After dumping Bios, got dead lap with continuous blinking led , the bios file is probably not the right one.
So please help with a working dump file for PLF / PLR / CSF / CSR / DSC MB REV. 2.1-
СообщениеДобавлено: 28 фев 2015 12:13
search.php?keywords=PLF+PLR+CSF+CSR+DSC&terms=all&author=&fid%5B%5D=384&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Поиск
check gpu
СообщениеДобавлено: 28 фев 2015 17:07
http://notebook1.ru/forma1/search.php?keywords=PLF+PLR+CSF+CSR+DSC&terms=all&author=&fid%5B%5D=384&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Поиск
check gpu
Platform is DSC.
Just for test purpose, I reflowed the integrated graphic chip with no avail.
СообщениеДобавлено: 01 мар 2015 11:25
there is no integrated graphic, only discrete - need new chip
СообщениеДобавлено: 01 мар 2015 13:52
Ye, y're right ! I got confused. it's discrete. I rather reflowed the AMD graphic chip for test purpose, with no avail.
You suggest then to change the AMD chip. So no way to fix it for the moment.
I got pro tools for the repair but unfortunately not yet a BGA machine!
СообщениеДобавлено: 03 мар 2015 15:09
3000 amd has no reaction to reflow.only new one needed
СообщениеДобавлено: 03 мар 2015 15:54
Customer agreed to change mobo with a good working used one.
Anyway thanks to every member having contributed to this thread.
