Текущее время: 09 июн 2026 23:50
 Заголовок сообщения: acer c730/cb3-111 ZHQ
СообщениеДобавлено: 25 окт 2018 22:28
hello
does anyone have schematics for quanta ZHQ CB3-111, please can you upload it .
thanks
 Заголовок сообщения: Re: acer c730/cb3-111 ZHQ
СообщениеДобавлено: 26 окт 2018 07:16
here ...
ZHQ_BTM-3A.pdf [1.03 МБ]
СообщениеДобавлено: 26 окт 2018 10:22
thankyou very very much.
cheers
СообщениеДобавлено: 30 окт 2018 22:42
hi the 3.3v and 5v ic here is RT6575C which is a equivalent of tps51225C i used the tps51225c on the vreg3 iget 4.5volts and vreg5 i get 6.8volts.but the rt6575c (5Y=) gives me vreg 3.3 okay and vreg5 okay the only problem is the +5v keeps tripping.has anyone put tps51225c instead of rt6575c as RT6575c is not available.
СообщениеДобавлено: 01 ноя 2018 22:57
okay so direct replacement for rt6575c = tps51225B i put the tps and it works now. now the boot goes in a loop and uses on a chrome os and flash drive.does anyone know how to reset the os or reinstall
thanks bregards
СообщениеДобавлено: 02 ноя 2018 21:59
hi so the case is solved first need to put hard reset
1) press esc + refresh + power
2) the press ctrl + D
3) enter and again enter to confirm
4) will reboot with fresh factory setting
note if your screen led backlite dont come on it is same procedure for it
thanks you all
