Текущее время: 25 апр 2026 13:39
 Заголовок сообщения: dell e5510 trun off after 3 second
СообщениеДобавлено: 30 апр 2016 18:38
hi every one
i have E5510.... i just replace cpu with greater one but not work and trun off after 3 second .... after 2 week i lose the itself cpu and i when i plug another cpu (intel i5 480m )in socket laptop not trun on and off after 3 second (amper about 0.10) BUT when i turn laptop without cpu laptop will turn on good and all voltages come such as
vtt0.75 -1.05v pch -1.5v ddr -3.3v sus -...... and all voltages good i thinks the board is ok but what the problem ?/?? note when i check PLATRST on (without cpu) no signal found ...
i change cpu core ic and BGA hm55 chip but not help
note when i plug cpu i have short on VTT voltage on PL5201 and L2702
help me please
 Заголовок сообщения: Re: dell e5510 trun off after 3 second
СообщениеДобавлено: 03 май 2016 11:53
Try to put a working processor .
Which model of motherboard , there is a picture on lcd, try easier bios thereby check the efficiency of the stick.
СообщениеДобавлено: 03 май 2016 14:24
thanks but not help ...... i checked i voltage on mainboard when not cpu present all is good ... but when i plugged cpu on vtt short present ...
СообщениеДобавлено: 04 май 2016 11:48
check cpu, if it is working 100 % that see power cpu, ic cpu, field-effect transistors power cpu lines
