Текущее время: 26 апр 2026 10:57
 Заголовок сообщения: UsingMini PCI-E to Desktop PCI-E Adapter for graphi testing?
СообщениеДобавлено: 20 июн 2018 13:22
Hi!
Wish to know from professionnels, if we can bypass Laptop internal failing graphic GPU and get display by using "Laptop Mini PCI-E to Desktop PCI-E Adapter Converter device"(see below link).
Thank you for a prompt reply.
https://ae01.alicdn.com/kf/HTB1DEo9KXXX ... 41823b5ada
 Заголовок сообщения: Re: UsingMini PCI-E to Desktop PCI-E Adapter for graphi test
СообщениеДобавлено: 20 июн 2018 16:34
perhaps, but not on all laptops, it all depends on the model.
СообщениеДобавлено: 21 июн 2018 13:37
Hi!
I know that the adapter is not compatible with all laptops. But I want to know if any member has had success in using the device to bypass laptop failing graphic chip ?
Thank you
СообщениеДобавлено: 21 июн 2018 14:27
I connected, because I could not get an image after replacing the GPU, it worked.
through a self-made adapter and riser.
IMG_20180621_132237.jpg [ 158.13 КБ | Просмотров: 2485 ]
СообщениеДобавлено: 21 июн 2018 19:23
That's great!!
Did you make the riser from scratch or bought a ready one ?
Do you have a sketch for connections between riser and adapter ?
Thank you
СообщениеДобавлено: 21 июн 2018 23:52
For a long time I did not remember exactly, I looked at the scheme.
СообщениеДобавлено: 21 июн 2018 23:59
tomorrow I'll make a photo pinout.
Зарегистрированные пользователи: Google [Bot], imobile2014, Yandex [Bot]
