Текущее время: 18 май 2026 13:06
 Заголовок сообщения: toshiba tecra s1 lcd display
СообщениеДобавлено: 08 мар 2009 23:10
when switch on the laptop the display comes on monitor and the have to press Fn+F5 only then the display come on the lcd screen everytime have to do this when boot up or switch on laptop .I have also changed the options in cmos bios and made lcd default but still i have to manually do it .does anyone know where the problem might be.
thanks again
repairs of laptops and selling of components
СообщениеДобавлено: 09 мар 2009 00:01
tecra s1 has videochip issue. that means, that this model has a potential failure with videochip. try to do reballing of this chip to make things clear for you. or just replace it.
СообщениеДобавлено: 09 мар 2009 02:50
Common comon tell me now
Is there somthing i should knew... (C)
СообщениеДобавлено: 09 мар 2009 03:40
alex, your English is terrible :)
 Заголовок сообщения: re lamo
СообщениеДобавлено: 09 мар 2009 16:51
lamo guess where the problem was. The suspend/lid switch was been pressed when i packed up the laptop so i had to remove the platic lever whic presses the switch now it works excellent. lamo do you have skype
СообщениеДобавлено: 09 мар 2009 20:51
and that's all? s easy? colleague, i'd like to recommend you, before posting here, to make all things clear(i mean, before asking 2 us, make all repairings yourself, like: bios reflashing,checking all connectors, etc). thus, you'll save our time and save your time.
ps. i don't have skype, regrettably, i even don't have much time to talk via ICQ fully.
Зарегистрированные пользователи: artyomov, Google [Bot], Yandex [Bot]
