Текущее время: 30 апр 2026 19:27
 Заголовок сообщения: Dell inspiron3542(Cedar_intel-mb 13269-1)Turns off after 2se
СообщениеДобавлено: 12 июн 2020 20:19
When you press the power button, the laptop turns on, a picture appears with the words Dell and immediately turns off. First of all, I flashed the BIOS from the off site,and replace the io chip I measured everything on the drosels, everything is normal, I also checked the on button. Disconnected the entire periphery, changed the RAM too,without RAM, the laptop does not turn off, on usb outputs it seems everything is all right. Tell me, can anyone come across such a problem ????
 Заголовок сообщения: Re: Dell inspiron3542(Cedar_intel-mb 13269-1)Turns off after
СообщениеДобавлено: 13 июн 2020 07:50
Remove Q2404. This is for diagnosis only )
СообщениеДобавлено: 14 июн 2020 13:22
no changes same as before
СообщениеДобавлено: 14 июн 2020 19:17
remove q2304 no changes
СообщениеДобавлено: 14 июн 2020 19:18
remove q2404 but no changes
