Текущее время: 17 май 2026 01:08
 Заголовок сообщения: toshiba dynabook a200
СообщениеДобавлено: 05 ноя 2009 21:35
i have this problem with toshiba a200 board made by inventec mb-a02 the laptop work well with battery but when connect the ac adapter no display.where can the problem bethis uses a winbond wpc8763ldg kbc intel ich8
repairs of laptops and selling of components
СообщениеДобавлено: 05 ноя 2009 22:51
no display - it is backlight off or picture is black with backllighting?
may be, but try to check INVERTOR in first and check lamp of backlight
step by step, left right left.
 Заголовок сообщения: re no display
СообщениеДобавлено: 06 ноя 2009 10:33
no display the inverter and backlight ok when using battery but if we use adapter then there is no display
СообщениеДобавлено: 07 ноя 2009 19:44
look volt... on invertors input/
how many?
fine!!!!!!!!!!!
the iljichs lamp beging light :D :D :D
press Fn+(key with bright logotip+) OK?
if not - chek BIOS/
СообщениеДобавлено: 08 ноя 2009 12:32
i suspect bios but cant find this model on the toshiba site .what a pain why do they make models like that. :cry:
СообщениеДобавлено: 08 ноя 2009 20:19
You tried to regulate buttons or not?
Brightness varies?
Can simply to a minimum brightness is lowered at power supply from the AC???
Insert the adapter and try! Brightness varies or not?
