Текущее время: 16 май 2026 15:56
 Заголовок сообщения: compaq 6720s display shift to left side
СообщениеДобавлено: 25 дек 2009 22:46
hello ,
i have some problem with hp 6720s the display is okay but shifted to left side of the lcd screen the right side is cut from 3inches changed the lcd screen also lcd cable .any idea where the problem is .
repairs of laptops and selling of components
СообщениеДобавлено: 26 дек 2009 13:02
you could see this if you installed wrong lcd-module in this laptop.
 Заголовок сообщения: re
СообщениеДобавлено: 30 дек 2009 00:33
what lcd you think will match with this model it use a 15.4"wide wxga but the screen in the laptopis orignal and work well in other laptops.what else can i check.
 Заголовок сообщения: Display
СообщениеДобавлено: 30 дек 2009 08:50
Problem is-your notebook incorectly initialized display.First help for this is-you can change eeprom data from old display and test.
