Текущее время: 07 май 2026 17:12
 Заголовок сообщения: hp dv6 ut1 amd
СообщениеДобавлено: 19 авг 2011 12:43
hello,
i have an hp dv6 laptop with ati 216-0729042 graphic and 215-0674034.i replaced the ati 216-0729042 chip now display comes but blank no characters on the lcd.check lcd and lcd cable.this has onboard graphic memory 64mb.
pls advice where the issue is.
 Заголовок сообщения: Re: hp dv6 ut1 amd
СообщениеДобавлено: 19 авг 2011 12:58
Do You have image on extrnal monitor?
If it true, the 216-0729042 not fit correctly, rework it again.
СообщениеДобавлено: 20 авг 2011 10:35
no on external monitor same problem but the monitor signal shows.but blank
СообщениеДобавлено: 20 авг 2011 12:38
What do You mean "now display comes"?
Are you sure that the new chip? Not reballed?
Check the BIOS post codes.
СообщениеДобавлено: 23 авг 2011 18:42
check PEG-capacitors resitance to gnd. from both sides.
http://soundcloud.com/dtmf
http://soundclick.com/dtmf
СообщениеДобавлено: 24 авг 2011 22:07
what should they be in ohms or kohms.i tried to see the signal on the oscilloscope but i guess you need atleast 250mhz .i use a 100mhz digital.thanks lamo will check and tell you.
