Hi, all welcome. Could I ask you for advice on my laptop?
Model: HP Pavilion DV7-6050ef
Motherboard: HPMH-40GAB6300-D00G
Project: FLEX COMPUTING H510UA1
Diagram (2).jpg [ 166.77 КБ | Просмотров: 948 ]
Laptop working, can boot up the system, but does not work keyboard , touchpad, audio, USB 2.0, USB 3.0 work it (When i connection keyboard in USB 3.0 and now open BIOS menu , I click one button and then When you press another button keypad is no longer responding, I have to re-connect keyboard and repeat).
Sata controller operates normally for connectors CN_ODD1 and CN_HDD1. But the connector CN_HDD2 not see the device.
1) I replaced the same southern bridge for new 218-0897020. No change.
2) I replaced the KBC ITE8518E. No change.
3) After some time I got to the schematic and found that Y101 does not oscillate (32.768KHz). I have replaced . On the Y101 it is + - 32 KHz. No change.
4) I again changed South Bridge for new compatible 218-08970214. No change.
f_0013627 (2).jpg [ 173.72 КБ | Просмотров: 948 ]
I measured on the SB820M:
Y3......25Mhz
+RTC_CELL..........3.3V
Y101..........33KHz
From CLK_P_ALINK to CLK_N_CR............everywhere is +- 350mV.
Please ask for your advice. It is a platform for very new and I do not know where to begin to solve the problem. Thank you.
Best regards chello123.
