Текущее время: 07 апр 2026 15:24
 Заголовок сообщения: USB port malfunction
СообщениеДобавлено: 17 июл 2013 19:38
Hi,
I got a HP DV5000 with usb issue : when I plug in any usb device, windows freezes and I need to unplug the device and restart windows.
Tested Usb port, seems ok :
pin 1 : GND
pin 2 : USB0+ =0,02V when device is unplugged and 3.9V when an Usb optical mouse is plugged
pin 3 : USB0- =always 0,02V with and without Usb mouse
pin 4 : USB0PWR= 5.67V
Noticed that optical mouse doesn't light when plugged in.
I suspect Southbridge fault ?
Has anyone experienced the same situation ? any clue for steps to solve the problem !
Platform : HAL 20 COMPAL LA2771
Thank you for your comment
 Заголовок сообщения: Re: USB port malfunction
СообщениеДобавлено: 18 июл 2013 00:49
Change southbridge..
СообщениеДобавлено: 18 июл 2013 01:53
I've no BGA machine.
I often reflow nvidia chips with high rate of success, but never tried to reflow southbridge. Is it possible to go for a Southbridge reflow to solve the issue ?
Thanks
СообщениеДобавлено: 18 июл 2013 14:21
no, reflow of the southern bridge will not help . only a replacement.
СообщениеДобавлено: 18 июл 2013 20:15
Thanks for your post.
Lack of BGA machine to change Southbridge, I will return the lap to customer.
Зарегистрированные пользователи: Google [Bot], walm, Yandex [Bot]
