Текущее время: 04 апр 2026 10:12
 Заголовок сообщения: Fujitsu siemens C1320D defaulting display to external
СообщениеДобавлено: 26 окт 2013 18:42
Hi!
Fuj siemens C1320D, came with no display on internal LCD, but displays on external.
After changing inverter, Lap always defaults POST screen display to the external monitor.
I always need to push Fn/F10, to change display to the internal, which is not practical.
Changing bios boot option to "auto" then to "internal LCd", did not help.
Any suggestion whether it's likely to be a hard or soft issue (bios to be updated...) and which steps to be taken consequently to solve problem?
 Заголовок сообщения: Re: Fujitsu siemens C1320D defaulting display to external
СообщениеДобавлено: 27 окт 2013 18:19
So have you updated the bios ?
СообщениеДобавлено: 29 окт 2013 21:27
Not yet, did you happen to solve a similar issue with bios update ?
I asked the customer whether he accepts to use fn-f10 for internal display or not, so as to avoid him extra-charges and I'm waiting for his final decision.
СообщениеДобавлено: 29 окт 2013 22:26
I have solved a ton of problems with bios update.
The very first step of repairing process is updating a bios.
Sometimes hardly connected issues is cured by that.
So do not avoid this first and absolutely necessary thing.
