Текущее время: 04 апр 2026 10:17
 Заголовок сообщения: LVDS Data signals checking.
СообщениеДобавлено: 03 ноя 2013 02:13
Hi,
Need comments on the following point:
I found on some laptops, with internal display fail :TXLOUT0+, TXLOUT1+, TXLOUT2+ = 0.6V to 0.9V (on LCD panel connector ).
May I consider them as normal voltages and conclude then that video LVDS signals are present on connector?
Thank you for your help.
 Заголовок сообщения: Re: LVDS Data signals checking.
СообщениеДобавлено: 03 ноя 2013 03:18
Those pins transmitting a digital signal, but ton linear. Use oscilloscope to view them.
СообщениеДобавлено: 03 ноя 2013 03:27
Hi!
Do you know what kind of signal to be found at TXLOUT0+ with oscilloscope ?
СообщениеДобавлено: 03 ноя 2013 03:32
some rectangle impulse. big frequency digital "0" and "1".
СообщениеДобавлено: 13 ноя 2013 22:53
hi, sorry for this late reply.
vitaliy_mad, I would appreciate getting any illustration of the signals to be checked with oscillos on lcd panel connector.
Thank you
СообщениеДобавлено: 14 ноя 2013 00:29
open any (almost) lcd screen pdf and view
by google something like that "LVDS signal photo"
resistance of lvds pairs must be identical
СообщениеДобавлено: 14 ноя 2013 23:14
hi! you mean that resistance of a pair of lvds (positive and negative signal) must be identical, but I guess each pair might have different resistance from an other pair
Thank you for replying.
СообщениеДобавлено: 14 ноя 2013 23:31
resistance between ground and each LVDS line must be same (identical)
СообщениеДобавлено: 15 ноя 2013 09:35
vitaliy_mad answered the question
you can take a few "good" motherboard and check it )
СообщениеДобавлено: 15 ноя 2013 11:12
You are wrong. It has long been checked. Resistance on all lines should be the same. The error is allowed in a few ohms.
СообщениеДобавлено: 15 ноя 2013 11:48
Так а я о чем пишу - "resistance of lvds pairs must be identical" - all lines
и предлагаю человеку проверить самому свои заблуждения на платах
вообще подобные вопросы задавать странно, есть сомнения ну возьми кучку плат и все станет понятно
СообщениеДобавлено: 15 ноя 2013 11:51
ну да сори. чет не дочитал. на этом форума много странных вопросов задают... :)
СообщениеДобавлено: 17 ноя 2013 18:09
We are here in the forum to learn from each other, and there is no limit to knowledge, so p.s never consider a question as strange (странно)!
СообщениеДобавлено: 17 ноя 2013 18:13
We are here in this forum to share our experience as knowledge has no limit, so p.s never consider a question as strange (странных)!
СообщениеДобавлено: 17 ноя 2013 20:10
I agree with you, and that's why I answered to your question. I hope it helped you.
СообщениеДобавлено: 17 ноя 2013 20:23
Anyway, thank you "vitaliy_mad". I already checked resistance on lvds signal pins on a working mobo, and find them almost identical, as you said.
