Текущее время: 04 апр 2026 10:17
 Заголовок сообщения: Toshiba M40-307 constant reboot
СообщениеДобавлено: 08 ноя 2013 01:56
Hi!
I'm dealing with 2 Toshiba sat M40-307, with same symptom : constant reboot after 15 to 20s, with no display.
GPU reflowed with no result.
Did anyone experience the same situation or have any clue ?
Platform : 6050A2028701-MB-A03
Should appreciate any help.
 Заголовок сообщения: Re: Toshiba M40-307 constant reboot
СообщениеДобавлено: 12 ноя 2013 22:46
Further to my post, wish to add :
Bios is phoenix.
Post card reading jumps directly from 00 to 86 and back cycle.
Current reading rises to 1.1V and down to 0V in a cycle of 6 times then lap shuts down.
p.s help as where to dig ?
Thanks
СообщениеДобавлено: 17 ноя 2013 17:04
Hi members,
No one encountered the same problem !!!
Quite surprised not to get any advice as where to dig since my first post, 10 days ago !
СообщениеДобавлено: 17 ноя 2013 17:16
mohkam писал(а):
Hi members,
So did not have such a problem if people did not respond :ne_ne_ne:
СообщениеДобавлено: 17 ноя 2013 17:31
RomaM65 писал(а):
mohkam писал(а):
Hi members,
But they might have faced similar situation with other Toshiba or other brands, so I need a guideline as where to dig ?
СообщениеДобавлено: 17 ноя 2013 20:25
Bios is phoenix.
Thanks
P.S read 1.1A and down to 0A
СообщениеДобавлено: 18 ноя 2013 01:54
The problem is well known. NB.
Reflow helps randomly. So you have to replace the chip.
СообщениеДобавлено: 18 ноя 2013 14:01
Hi Panasonic! nice to hear from you.
I'll try a 2nd reflow and will post back. Unfortunately I'm not yet equipped with BGA machine.
СообщениеДобавлено: 18 ноя 2013 22:03
You can create it by yourself, it not that hard .
First of all you need a good heating "bottom".
It should be a square surface controlled by some regulator and
wide enough to fit a mobo.
You might use an electric grill, a stove, an oven, whatever to heat up
the bottom side of a mobo following two conditions: the heating process must be
gradual by time and even by square.
To get the graduality you can use PID like this
http://www.aliexpress.com/item/Dual-Dig ... 07874.html
To obtain the evenness you can use a temper glass from an electric bake oven.
The glass is also a good surface to put a mobo on using small teflon or even metal stands.
For upper heating device you can use a heat air gun.
Also you might need a pair of multimeters with thermocouples to measure bottom side and
the area near the soldering chip. Or just one for calibrating of PID target temperature to achieve
about 170C on the bottom side and for further additional control of upper heating.
The upper works you can do manually (visually) checking the melting temperature.
СообщениеДобавлено: 19 ноя 2013 16:35
Do not forget that the reflow is just a diagnostic measure not a repair.
СообщениеДобавлено: 20 ноя 2013 22:24
Thank you for the idea, which I guess is not difficult to achieve.
I can use for upper heating my "yaxun_863D" BGA infra-red station, which I bought some months ago and didn't yet get good control of it.
