Текущее время: 16 апр 2026 06:35
 Заголовок сообщения: HP ELITEBOOK 8560P (CURE-UMA_HR_HPB) No SOUND(Audio)
СообщениеДобавлено: 27 фев 2015 15:16
helloo
i have a HP Elitebook 8560P with NO sound comming from the peackers or from headphones.
I ALLREADY checked:
*several drivers and windows versions (everything looks normal in device manager)
*BIOS update
*different speackers
* checked the jacks
* changed the IDT 92HD080B1X5
AND still the same problem, the device is installed i can turn volume up and down..but no audio!
ANY OTHER IDEEA?
 Заголовок сообщения: Re: HP ELITEBOOK 8560P (CURE-UMA_HR_HPB) No SOUND(Audio)
СообщениеДобавлено: 27 фев 2015 15:20
try to install clean OS, may be at another HDD. then, check powers on codec ic, and sens out/input on jack and ic. also, if u have oscillator check signal transmited to codec and recived to amp. check mute signal.
СообщениеДобавлено: 27 фев 2015 15:30
i allready tried different hdd and OS
Checked power on codec IC-ok, cecked sense on jack - ok, i cannot identify the AMP, since i don't have a schematic..
СообщениеДобавлено: 27 фев 2015 15:34
it usually placed near whith codec, but ithink it ok, amp used only for speakers, usually.
what about oscilloscope?
СообщениеДобавлено: 27 фев 2015 15:45
unfortunately, i don't have one...but IDT codec chip was changed
