Текущее время: 16 апр 2026 13:37
 Заголовок сообщения: Lenovo M5400 (DA0BM5MB8D0 Rev. D) No Power
СообщениеДобавлено: 13 мар 2015 13:35
Hello
i have a Lenovo M5400 DA0BM5MB8D0 Rev. D
when i connect the AC adapter the Power LED is blinking 3 times, and THAT is ALL. It will not power ON, or do anything!
I have 3.3v on power button, i have 3.3v and 5V on motherboard.
Also tried to Flash 2 versions of BIOS (both EC and KBC).
not shure but i think is a bios problem. if anyone has WORKING and TESTED dump, please share.
 Заголовок сообщения: Re: Lenovo M5400 (DA0BM5MB8D0 Rev. D) No Power
СообщениеДобавлено: 13 мар 2015 22:45
viewtopic.php?p=663427#p663427
или
http://vlab.su/viewtopic.php?p=179234#p179234
Information is the most dangerous weapon of all...
СообщениеДобавлено: 16 мар 2015 14:09
thank you for your reply, i tried both versions of bios but still the same...
the laptop won't power on! the only sign of life is the battery LED flashing green 3Times when i connect the charger.
any other ideea what can be wrong?
СообщениеДобавлено: 20 мар 2015 16:40
no one? no ideea?
do you have datasheet, schema for this board?
СообщениеДобавлено: 16 апр 2015 12:57
Hello
my version of MB had both BIOS and EC, Meaning U44(25L32) and U45(25L64)
i measured Vcc(pin 8) on the chips and after charger is connecte i have no Vcc and after i press the porwe button i get 3,33V ONLY on U44. i have no Vcc on U45.
anyone have a datasheet for this motherboard?
Зарегистрированные пользователи: Google [Bot], IhorD, mochailo, Yandex [Bot]
