Текущее время: 23 апр 2026 06:56
 Заголовок сообщения: laptop won't turn on
СообщениеДобавлено: 02 янв 2016 04:19
laptop won't turn on. can somebody help me diagnose the problem? fans just spinning. no video
 Заголовок сообщения: Re: laptop won't turn on
СообщениеДобавлено: 02 янв 2016 09:11
Can you say model of laptop, platform of mainboard and discribe problem?
СообщениеДобавлено: 02 янв 2016 12:07
you first go read viewtopic.php?f=232&t=37903 sweat Understanding the door, diagnostics, Opportunity viewtopic.php?f=232&t=87309 and sweat syuda Kratkoe posobye beginner ... http: //notebook1.ru/forma1/viewtopic.php? f = 232 & t = 103364
СообщениеДобавлено: 02 янв 2016 16:35
Model is HP G60. Mainboard is Wistron Warrior2. Turns on but does not show video.
СообщениеДобавлено: 02 янв 2016 20:43
If laptop turned on, but doesn't show video, you'll need check:
1. upgrade BIOS via programmer
2. plug in debug card and check POST-codes
3. check RAM modules
4. check RTC-battery voltage
Can you say more information about laptop's history?
what did you do before laptop has broken?
Did you do any diagnostic? Describe all your operations...
СообщениеДобавлено: 03 янв 2016 06:01
Don't have a BIOS programmer nor debug card. I changed RAM modules with known working ones and still same issue. The RTC-battery is good @ 3.25 V. I recently replaced the screen because the backlight was bad.
СообщениеДобавлено: 03 янв 2016 10:16
Do you have video on external output: VGA(D-Sub), HDMI?
P.S.:
without toolkit for repair you won't fix issues
you'll need to go to laptop's repair service
СообщениеДобавлено: 03 янв 2016 16:32
No video on external outputs either.
