Текущее время: 22 апр 2026 20:08
 Заголовок сообщения: Lenovo Z510 (AILZA NM-A181 REV:1.0)
СообщениеДобавлено: 26 мар 2016 00:48
Good day.
I got few questions for you:
I got this laptop today with strange problem. When the power is connected the current draw from power supply is around 200mA (0.20A). I have both standby voltages but the strange thing is that the CPU coils are heating a bit and the voltage is 1.7V both either CPU inserted into motherboard or not.
The Lenovo IT8586 FXA chip is heating a lot but the strange part is that the CPU voltages are present even if the board is not powered on.
When buying ITE chip, what about those leters: FXA, FXS, EXA, EXS, CXA, CXS? Any explanation about the letters? Do I have to order the same version or I can put other one?
Any info is appreciated.
Below are some pictures with thermal vision.
Комментарий к файлу: CPU side
napred.jpg [ 160.45 КБ | Просмотров: 539 ]
Комментарий к файлу: CPU side thermal
napred thermal.jpg [ 127.16 КБ | Просмотров: 539 ]
Комментарий к файлу: Back side
pozadi.jpg [ 171.44 КБ | Просмотров: 539 ]
Комментарий к файлу: Back side thermal
pozadi thermal.jpg [ 144.28 КБ | Просмотров: 539 ]
