Текущее время: 16 апр 2026 23:06
 Заголовок сообщения: Aspire 7520G (LA-3581P rev3.0) no +3VALW, no +5VALW.
СообщениеДобавлено: 28 апр 2017 00:15
Hi guys!
This one is missing +3VALW. Actually its not missing, it jumps 0-3V and also LDO5 jumps 0-4V.
The enable signal (MAINPWON) for PU3 (MAX8744E) ALSO jumps.
At PL4, +5VALW is always 0, no jumping.
I measure no shorts at PL3 and PL4, 0.119 at diode mode. Also LDO5, 0,497 at diode mode.
I replaced two LM393 (PU2 and PU6), MAX8744E (PU3), KB926 (ENE I/O) and reflashed BIOS.
I also removed the MXM and CPU to take measurements. Nothing changed.
Please advise if you have experience with this issue.
BR,
george
Комментарий к файлу: schematic
ICW50 LA-3581P R10 0420 Acer Aspire 7520 7220 5520 5220.pdf [1.14 МБ]
 Заголовок сообщения: Re: Aspire 7520G (LA-3581P rev3.0) no +3VALW, no +5VALW.
СообщениеДобавлено: 28 апр 2017 14:01
B+ не просаживается ?
ключи PQ11,PQ12 целы?
СообщениеДобавлено: 28 апр 2017 14:03
при питаниии от батареи какая ситуация ?
СообщениеДобавлено: 02 май 2017 12:44
unfortunately the customer required the laptop to be returned. He also did not have a battery to test that option.
PQ11, PQ12 were ok... :(
thank you for your interest my friend. till next time!
br,
george
