Текущее время: 09 апр 2026 13:34
 Заголовок сообщения: Acer E5-573G Quanta ZRT touchpad don't working
СообщениеДобавлено: 22 ноя 2020 00:33
Hi all, I have a problem with Acer E5-573G, mb: DA0ZRTMB6B0
Problem description:
Laptop after other service. Motherboard without bios chip - upload dump with clean me region and soldered chip - works fine. Next, I noriced a problem with battery charging - repaired. All works fine without touchpad.
FN+F7 checked.
Value on TP CON CN7
1. 3.3V +TPVDD
2. 0V TPCLK_R
3. 3.3V TPDATA_R
4. 0V GND
5. 3.3V I2C_TP_SDA_R
6. 3.3V I2C_TP_SCL_R
7. 0V TPD_INT#R
8. 3.3V TPD_EN_R
Checked resistance, resistors and wire TPCLK signal - all ok. Replaced KBC and touchpad - no change.
I found topic on vlab forum with same problem. One of the users write that it's problem with i2c tp address. Does anybody have this script from this topic?
http://vlab.su/viewtopic.php?f=59&t=101 ... F1uFqtuswo
 Заголовок сообщения: Re: Acer E5-573G Quanta ZRT touchpad don't working
СообщениеДобавлено: 22 ноя 2020 12:55
check I2C Device in windows device manager
TP tool x64.zip [544.94 КБ]
СообщениеДобавлено: 22 ноя 2020 22:46
I2C HID device have an exclamation mark in device manager. I'll try script tomorrow. Thanks for upload.
СообщениеДобавлено: 24 ноя 2020 14:39
Touchpad alive. :)
Зарегистрированные пользователи: di.mas, dm688, Google [Bot], Yandex [Bot]
