Текущее время: 21 май 2026 21:43
 Заголовок сообщения: расшифровка сигналов
СообщениеДобавлено: 09 дек 2020 18:25
расшифровка синалов для начинающих
AC : Alternating current
ACDRV : AC adapter to system-switch driver output
ACEDET : Adaptor Current Detector
ACGOOD : Valid adapter active-low detect logic open-drain output
ACIN : Adaptor Current sensor Input
ACN : Adapter current sense resistor
ACOP : Input Over-Power Protection
ACOV : Input Overvoltage Protection
ACP : Adapter current sense resistor, positive input.
ADP+ : Adapter Positif Suplay
ADP_ID : Adapter Identity
AGND :Analog Ground
ALWP :ALWAYS ON POWER
B+ : AC OR BAT POWER RAIL FOR POWER CIRCUIT
BATT : Battery
BAT+ :BAT POWER RAIL FOR POWER CIRCUIT
BAT_DRV :Bat Fet Gate Driver
BAT_V Battery Voltage
BOM :BILL OF MATERIAL MANAGEMENT
BT :BUTTON
BT_EN :Bloototh Enable
BUZER :Connected
BYP :Baypass
CHGEN : Charge enable active-low logic input
CIN : Input Capacitor
CLK_EN :CLKOCK ENABLE
CN :CONECTOR
CRT :Cathode ray tube
CSIN :Current Sensor input Negatif
CSIP :Current Sensor input Positif
DC Direct current
DM IM/DIM SOCKET/SOKET MEMORY/SOKET DDR
DOCK DOCKING SOCKET
EC :Embedded Controler
EC_ON :Embeded Controler Enable
EMI :Elektromagnetik Interference(GANGGUAN ELEKTROMAGNETIK)
EN :ENABLE
ENTRIP :Enable Terminal
F :FUSE
FSEL : Frequency Select Input.
GATE : Trigger gate
GND :Ground
GP :GROUND PIN
GPI :General Power Input
GPIO :General Power Input Output
HDMI :High-Definition Multimedia Interface
ID :Continuous Drain Current
IDM : Pulsed Drain Current
IIN : Operating Supply Current
IIN(SHDN): Shutdown Supply Current
IIN(STBY): Standby Supply Current
IS :Continuous Source Current (Diode Conduction)
IVIN :Battery Supply Current at VIN pin
JP :JUMPER POINT
KBC :Keyboard Controler
LCDV :LCD POWER
LDO :Linear Driver Output
LGATE : Lower-side MOSFET gate signal
LPC :Low Pin Count
LVDS :Low-voltage differential signaling(SYSTEM PENSIGNALAN)
MBAT :MAIN BATTERY
NB :North Bridge
ODD :OUTPUT DISC DRIVE
PCI : Peripheral Component Interconnect
PGOOD : Power good open-drain output
PIR : PRODUCT IMPROVED RECORD
PSI# :Current indicator input
PVCC : IC power positive supply
RSMRST : Resume Reset
RTC :REAL TIME CLOCK
SB : South bridge
SHDN :Shutdown
SYS_SDN :System Shutdown
SPI :Serial Peripheral Interface
TD Death Time
THRM :THERMAL SENSOR
TMDS :Transition Minimized Differential Signaling(TRANSMISI DATA TEKNOLOGY)
TP :TESt POINT
TPAD :THERMAL PAD
UVLO : Input Undervoltage Lock Out
V :RAIL(POWER)
V+ : Positive Voltage
VADJ : Output regulation voltage
VALW :ALWAYS ON POWER
VALWP :VALW PAD
VBAT :BATTERY POWER
VCCP : power chip(ich,graphic chips)
VCORE : POWER PROCESOR
VDD : Control power supply
VDDR : POWER DDR (VDRAM/VRAM/VMEM)
VDS :VOLTAGE DRAIN SOURCE
VFB : feedback inputs Power
VGS :VOLTAGE GATE SOURCES
VIN : Input Voltage Range
VIN :ADAPTER POWER SUPLAY(vol_in)
VL : Power Lock
VL :voltage across the load/Tegangan beban resistor
VL :Voltage Linear
VLDOIN : Power supply of the VTT and VTTREF output stage (to powerMOS).
VOT :Volt_out
VRAM : Power Memori
VREF : POWER REFERENCES/SCHEMA REFERENCE/PERMINTAAN SKEMA
VS :SUITCH POWER
VS+ :SUPPORT VOLTAGE POSITIF
VSB : POWER SWITCH BUTTON
VSS : Signal ground.
VSW : POWER SWICT
VTT : Memory Termination Voltage
VTERM :Memory Termination Voltage
VUSB : POWER USB
VGA : POWER VGA (VGPX/VGPU/VCVOD)
VGFX : POWER GRAPHIC CHIP
VREF :VOLTAGE REFERENCES
 Заголовок сообщения: Re: расшифровка сигналов
СообщениеДобавлено: 10 дек 2020 08:31
Инфа полезная, но в 2020 году неактуальная. Сейчас все поголовно по ютубам ремонтируют, а там глубоко пофигу на эти непонятные буковки.
Ремонт ноутбуков в Петропавловске (Казахстан)
+7-7152-50-16-72
+7-707-150-16-72
СообщениеДобавлено: 11 дек 2020 17:40
зато сложное почти никто не делает
что очень радует
СообщениеДобавлено: 12 дек 2020 19:24
Очень полезная
СообщениеДобавлено: 17 янв 2021 18:52
"Начинающий" - это как "малолетний дебил" - состояние души, а не то то вы там себе выдумываете)
А шпаргалки вроде ещё никому не вредили
СообщениеДобавлено: 17 янв 2021 22:33
Это точно!)))
Спасибо Максиму! Ещё бы параллель для Маковских обозначений... Где-то кстати у меня была шпоргалка по Маковским аббревиатурам...
СообщениеДобавлено: 18 янв 2021 20:37
Выложите
СообщениеДобавлено: 03 май 2021 11:30
Максим, исправьте некоторые строчки, а то глаз режет. Это то что прям сразу в глаза бросилось :)
ODD :OUTPUT OPTICAL DISC DRIVE
CLK_EN :CLKOCK CLOCK ENABLE
VS :SUITCH SWITCH POWER
VSW : POWER SWICT SWITCH
Зарегистрированные пользователи: Google [Bot], Yandex [Bot], ZEOS40
