Текущее время: 04 апр 2026 14:53
 Заголовок сообщения: HP ProBook 4530s (RAMONES 6050A2465501)
СообщениеДобавлено: 06 мар 2015 20:39
Hi to all.
I have a problem with this HP notebook.
- A customer has spilled a liquid on it and it wouldn't turn on. I found a problem with U9426 chip (TPS51123) and have successfully exchanged the chip and repaired that part of a problem.
- Now the laptop is starting but I have another problem I can't solve. When I turn it on, it displays HP image and it wont go any further, it freezes.
When I enter BIOS, I can do whatever I like in BIOS, change settings, etc... But when I try to exit BIOS to save changes or to select boot devices, it freezes. The notebook won't boot past BIOS screen.
I have exchanged SMSC chip, and a couple of Intel CPU's, tried another main BIOS, but nothing helps. It is always the same.
What do you recommend to do next?
 Заголовок сообщения: Re: HP ProBook 4530s (RAMONES 6050A2465501)
СообщениеДобавлено: 07 мар 2015 01:13
Most likely a problem with the south bridge . Or with any of its interface (LAN, Audio ...). And can be a problem with the BIOS firmware.
СообщениеДобавлено: 07 мар 2015 19:52
I have already exchanged the BIOS and SMSC chip with another board I have laying around here. I have checked all the voltages, everything seems fine.
I can enter BIOS when laptop turns on, and when I stay in BIOS, the laptop works. I can stay in BIOS setup for how much as I want and the laptop does not freezes at all, but when I try to save settings or boot past BIOS screen, the laptop will freeze.
The only thing left to change is Intel HM65 chipset.
These are the pictures of the donator board I have laying around here.
СообщениеДобавлено: 08 мар 2015 11:06
A scheme on the motherboard there is some flash chip should stand ? It may well be that different firms chips differ in speed reading and writing , as a result of the laptop can not work at all , although the chip and firmware will be working in it the same .
СообщениеДобавлено: 12 июл 2015 20:36
It seems that there is a password somewhere in BIOS and I cannot find in which chip is the password. Can you help me to identify the chip and erase password? Thank you!
СообщениеДобавлено: 13 июл 2015 00:23
djdzo
I think the problem is the hard drive, try to pull it out and turn on the laptop.
СообщениеДобавлено: 18 авг 2015 13:31
No it's not hard drive, I am powering the laptop on the bench, without any peripheral device, no hard drive, no DVD drive, no keyboard... only the board, the screen and the USB keyboard
Зарегистрированные пользователи: Google [Bot], servis67, Yandex [Bot]
