Текущее время: 17 апр 2026 04:38
 Заголовок сообщения: sony SVF14 (DA0HK8MB6E0) not charging
СообщениеДобавлено: 11 июл 2015 23:39
 Заголовок сообщения: Re: sony SVF14 (DA0HK8MB6E0) not charging
СообщениеДобавлено: 03 авг 2015 23:06
power boot normally. After machine installed battery does not boot, disassemble, others not analyzed, according to the drawings one by one check. How it does not work, then also try holding the CMOS battery put it, a miracle happened, everything is normal. We do not want to run into the same trouble again struggling checked
