Текущее время: 28 апр 2026 12:08
 Заголовок сообщения: HP DV6 (da0ut3mb8d0) clicking sound when CPU in socket
СообщениеДобавлено: 28 авг 2017 13:32
Hi guys,
This one (da0ut3mb8d0, dv6, discrete nvidia, ddr2) is making a clicking noise when the adapter is connected.
The 5V_ALWP and 3.3_VALWP have noise and also I can see noise with the oscilloscope on PL6 (I see pulses).
When I remove the CPU then the noise disappears and 5&3V_ALWP stabilize! NO NOISE.
I tried different CPU, I replaced ISL6262A (PU1), I measured for short and also disconnected 330uF capacitors. No solution.
When PL6 is also disconnected then again there is no noise and the machine can TURN ON! I do not have the LCD but extrernal monitor gives no image... the CAPS lock is flashing, VCORE=0V and I already tried flashing the BIOS.
Is it maybe the VGA? Will try to reball it today...
any other ideas about the clicking? If I connect PL6 the clicking comes back and there noise in the motherboard. no turning on.
br,
geoge
 Заголовок сообщения: Re: HP DV6 (da0ut3mb8d0) clicking sound when CPU in socket
СообщениеДобавлено: 29 авг 2017 15:12
unfortunately no solution found, the laptop was returned to the customer.
