Текущее время: 21 апр 2026 18:48
 Заголовок сообщения: ACER E1-532 No image (V5WE2 LA-9532P)
СообщениеДобавлено: 25 окт 2015 15:17
Hi to all.
I have got yet another Acer E1 motherboard that I cannot solve.
Everything seems fine, I have all the right voltages, the board is drawing around 450mA when turned on, I have no image on screen. Somebody else tried to reflow the Intel chip.
I also cannot find the right bios for this board, it has only one bios chip - U6, the KBC bios is not present on the board. I have tried couple of images I found on the forum, but no luck, still no image on screen. The battery voltage is also good - 3,1V
V5WE2 LA-9532P
REV: 1A
ENE KB9012QF A3
Intel SR1DU (Intel Celeron 2955U)
Изображение Изображение
What do you recommend I should do?
Thank you!
 Заголовок сообщения: Re: ACER E1-532 No image (V5WE2 LA-9532P)
СообщениеДобавлено: 25 окт 2015 15:32
First try to flash BIOS...
Then CPU and RAM just settle other...
СообщениеДобавлено: 25 окт 2015 15:40
I have tried about 6-7 different bios files. No luck with them. I tried a couple other RAM memories.
CPU chip is the only chip on the board (all in one chip), and it has to be desoldered to be changed. I have no spare one.
СообщениеДобавлено: 25 окт 2015 17:56
Resolved... KBC bios was the problem...
Зарегистрированные пользователи: Google [Bot], Mihed, Yandex [Bot]
