Текущее время: 23 апр 2026 06:53
 Заголовок сообщения: Please Help!! quanta R33 board ACIN problem.
СообщениеДобавлено: 16 янв 2016 10:33
Hi.... good morning all.
Please all laptop repair exparts try to help me.
DAR33HMB6A0 REV: A
works with battery, not work with adapter.
I check PU9 ACIN=0v
Pin20 vcc=19v
pin6 acdet=2.7v
Pin16 REGN=6v
so changed Charging PWM pu9.
But not solved.
Please help for this problem.
thanks.. :a_g_a:
 Заголовок сообщения: Re: Please Help!! quanta R33 board ACIN problem.
СообщениеДобавлено: 16 янв 2016 11:43
Check PU9 ACIN resitance, if it low try to unsolder pr177
after this check again PU9 ACIN resistance, if its ok change PU13
СообщениеДобавлено: 16 янв 2016 13:10
You are great! : :bra_vo:
Thanks for your help.
Pu13 was bad. :co_ol:
