Текущее время: 22 апр 2026 02:58
 Заголовок сообщения: ASUS X553M (X553MA Rev.2.0) random shut down
СообщениеДобавлено: 23 июл 2016 04:14
ASUS X553M
ASUS X553MA Main Board
Rev:2.0
Intel Mobile Celeron N2840 (SR1YJ)
ITE IT8985E AXA
I got 3 of these notebooks with similar problem and I can't find the right solution, so I am hoping you can help me.
1. First Asus X553M came to me with the problem of shutting down after 30min of work. As expected I programmed an clear ME region bios and the laptop works different after bios update. Sometimes it can work for couple of days without shutting down, but some days it can go off in 10 minutes after power on. No rules at all. I exchanged everything there is in laptop and the problem is still present. Another RAM, HDD, WiFi, Keyboard, Screen.... nothing works. Laptop is turning off randomly.
I managed to find out that when the WiFi is not in laptop, it works good. When the WiFi is in laptop, than it is turning off randomly.
2. Other two ASUS X553M are from another company, both have the random turn off symptoms. I tried with clear ME bios but the problem is still present.
What do you recommend to do?
Thank you!
 Заголовок сообщения: Re: ASUS X553M (X553MA Rev.2.0) random shut down
СообщениеДобавлено: 23 июл 2016 08:07
most of these problems are solved factory TXE
X553MAF1.part1.rar [2 МБ]
X553MAF1.part2.rar [1.12 МБ]
Зарегистрированные пользователи: BlackDoc, Google [Bot], Yandex [Bot]
