Текущее время: 18 апр 2026 15:29
 Заголовок сообщения: lenovo yoga /intel i3/help to identify badcaps
СообщениеДобавлено: 15 дек 2016 23:36
Hi ,
this motherboard doesn't start , 2 capacitor are very hot when i plug in.
i don't have schématic
Can you tell me which value have these caps ?
many thanks
http://zupimages.net/viewer.php?id=16/50/ei7b.jpg
http://zupimages.net/viewer.php?id=16/50/r73x.jpg
 Заголовок сообщения: Re: lenovo yoga /intel i3/help to identify badcaps
СообщениеДобавлено: 16 дек 2016 01:38
10uF x 25V should fit.
(look at the scheme here:
viewtopic.php?f=78&t=86601
it is OZ8153-based, looks very close to your's OZ8150-based, but two-channels)
СообщениеДобавлено: 17 дек 2016 14:19
Hi ,
i'll try to change by 10µF and i'll tell you
many thanks
Best regards
СообщениеДобавлено: 20 дек 2016 16:35
Hi ,
i changed caps , laptop start and shutdown immédiatly without screen.
If I disconnect the battery it starts up and works correctly.
How I can test the battery is short ?
Best regards
СообщениеДобавлено: 12 янв 2017 01:28
Hi
i tried with new battery it's same .
what i have to check ?
best regards
Зарегистрированные пользователи: Google [Bot], Sarkits, Yandex [Bot]
