Текущее время: 25 апр 2026 16:27
 Заголовок сообщения: Toshiba C600 - reseting setting after power disconnect
СообщениеДобавлено: 26 мар 2018 23:10
Hi everybody,
Im having Toshiba C660-1J1, its a Intel platform with UMA graphics. Problem is that on every power disconnecting ( battery is not present because its bad ), than after plug in charging cable, BIOS is reset and I need to configure again date and time. I was changed CMOS battery, nothing hapenned. After than changed BIOS chip and programmed with another dump, still present problem. At the end, i was changed KBC controller, cause I found somewhere that setting is stored in them, but nothing, problem is still present.
Is anyone have idea, whats next :du_ma_et: :du_ma_et: Where is stored settings configured in bios?
 Заголовок сообщения: Re: Toshiba C600 - reseting setting after power disconnect
СообщениеДобавлено: 26 мар 2018 23:42
Check the 32kHz oscilation at hub when the power disconected. May be just a RTC circuit damage?
Зарегистрированные пользователи: Google [Bot], Vitaslon, Yandex [Bot]
