Текущее время: 14 май 2026 21:10
 Заголовок сообщения: Broken pad on Nvidia 180-10410-0000-A01
СообщениеДобавлено: 17 окт 2011 13:07
Hi all. I can't speak Russian so I write this post in English. My problem is a graphic card. It has corroded pad. Please look at the picture. Can someone tell me where this pad needs to be connected please?
http://imageshack.us/photo/my-images/143/43955222.jpg/
 Заголовок сообщения: Re: Broken pad on Nvidia 180-10410-0000-A01
СообщениеДобавлено: 17 окт 2011 15:24
if u shure that problem in it? use thin wire (isert it into the metalized hole which is black on he picture) clean the protective green layer and solder it with the acid flux.... But it seem`s to me that the problem is in the GPU
СообщениеДобавлено: 17 окт 2011 15:27
The metal gone. There is no point to solder to. Laptop is working fine but has white screen.
СообщениеДобавлено: 17 окт 2011 15:48
there is only 1 side of board. show another please.
СообщениеДобавлено: 17 окт 2011 18:34
Have you checked your motherboard with another graphic card?
