Текущее время: 15 май 2026 07:36
 Заголовок сообщения: HP DV7-6050ef, MB: HPMH-40GAB6300-D00G problem with SB820M
СообщениеДобавлено: 23 дек 2012 01:03
Hi, all welcome. Could I ask you for advice on my laptop?
Model: HP Pavilion DV7-6050ef
Motherboard: HPMH-40GAB6300-D00G
Project: FLEX COMPUTING H510UA1
Вложение:
Diagram (2).jpg [ 166.77 КБ | Просмотров: 954 ]
Laptop working, can boot up the system, but does not work keyboard , touchpad, audio, USB 2.0, USB 3.0 work it (When i connection keyboard in USB 3.0 and now open BIOS menu , I click one button and then When you press another button keypad is no longer responding, I have to re-connect keyboard and repeat).
Sata controller operates normally for connectors CN_ODD1 and CN_HDD1. But the connector CN_HDD2 not see the device.
1) I replaced the same southern bridge for new 218-0897020. No change.
2) I replaced the KBC ITE8518E. No change.
3) After some time I got to the schematic and found that Y101 does not oscillate (32.768KHz). I have replaced . On the Y101 it is + - 32 KHz. No change.
4) I again changed South Bridge for new compatible 218-08970214. No change.
Вложение:
f_0013627 (2).jpg [ 173.72 КБ | Просмотров: 954 ]
I measured on the SB820M:
Y3......25Mhz
+RTC_CELL..........3.3V
Y101..........33KHz
From CLK_P_ALINK to CLK_N_CR............everywhere is +- 350mV.
Please ask for your advice. It is a platform for very new and I do not know where to begin to solve the problem. Thank you.
Best regards chello123.
 Заголовок сообщения: Re: HP DV7-6050ef, MB: HPMH-40GAB6300-D00G problem with SB82
СообщениеДобавлено: 23 дек 2012 04:40
Sorry, but I didn't find in your post, anything about bios and firmware. Did you try anything to do on this way?
СообщениеДобавлено: 23 дек 2012 13:53
Hello, thank you for your answer. Yes, I updated the bios in windows to the latest F.21, no change. Unfortunately binary copy for reprogramming I never found or was he dead link . It would be available somewhere?
Thank you.
СообщениеДобавлено: 23 дек 2012 19:27
Hello, I just managed to find a binary copy of the BIOS. I reprogrammed the EEPROM. But it is still the same.
What is the reason that stopped working Y101?
It is not possible that a device has been connected to the south bridge, device it bad (such as audio) ?. How to identify him but when CLK is working? Can not block SB820M from damage?
Вложение:
USB21.jpg [ 286.96 КБ | Просмотров: 929 ]
I tried to measure the USB 2.0 contacts from USB_HSD0N to USB_HSD1P. If connect flash drive signals appear 1.75V, without Flash Drive --> 0V, in bios not see. The USB 3.0 is 3.15V(DATA+,DATA-), but keyboard in USB3.0 after pressing a button does not respond.
Please can you think of any signals that I measure?
Thank you.
