Текущее время: 15 май 2026 19:58
 Заголовок сообщения: hp630 regular shut down after 15 to 20"
СообщениеДобавлено: 15 фев 2013 23:03
Hi every one!
I'm dealing with hp630, which shuts down after 15 to 20". I tried with a bare board (mobo + proc +memory only), same thing, shut down at bios screen.
I tried the trick of pushing power button for 30 to 40", cleaned fan and put new paste, same problem.
I noticed that before shutting down, the fan spins at full speed and becomes noisy. No excessive heat of chips.
When running without ram (DDR3), it never shuts down. Tested with new good ram, same problem.
P.S help !!
Should appreciate getting schematic of hp630.
Thanks
 Заголовок сообщения: Re: hp630 regular shut down after 15 to 20"
СообщениеДобавлено: 15 фев 2013 23:09
Write a platform
Do full dump of BIOS ic by burning machine and upload.
СообщениеДобавлено: 15 фев 2013 23:12
Also you can to burn this (do a backup first)
http://notebook1.ru/forma1/viewtopic.php?f=232&t=78789
СообщениеДобавлено: 19 фев 2013 16:13
RsM писал(а):
Write a platform
hp630 platform :i3-380M
Does the dump file you link to, refer to this platform ?
Meanwhile, for unknown reason, lap became in a dead situation : 3.5V and 5V are now absent. No short circuit found, will dry solder IC and see.
I have to relieve this new situation first, unfortunately, I have no schematic.
СообщениеДобавлено: 19 фев 2013 20:00
mohkam писал(а):
hp630 platform :i3-380M.
There is not a platform !!! :ad_min_v_duhe:
platform identification
СообщениеДобавлено: 25 фев 2013 01:27
Sorry, platform is CHICAGO_CP_HPC MV_MB_V2.
I already got CHICAGO_I_HR_HPC_S (Intel) schematic through this forum.
Further steps made to fix the new issue (no 3.5V and 5V ALW) :
Dry solder IC didn't help. Found Vin supply current limiting resistor grown in value and changed it. After replacement, TPS51123 became very hot.
I think it needs to be replaced.
As TPS51123 is not now available in our market, is there any recommended IC replacement i.e Max, Winbond or any other...?
Any help is welcome!
СообщениеДобавлено: 25 фев 2013 03:12
RT8223BGQW, but compare the datasheets...
СообщениеДобавлено: 02 мар 2013 00:14
Yes, "svs198", RT8223B should suite as replacement for TPS51123.
RT8223A might be also a replacement through a small modification.
Unfortunately, both are not yet available on our market!
Anyway, thank you for your suggestion.
СообщениеДобавлено: 02 мар 2013 00:47
Check the heat transfer tube. I have met a few times at once on HP this model line
СообщениеДобавлено: 02 мар 2013 19:37
By "heat transfer tube", do you mean to check any tube for abnormal heat or a specific one ?
Thank you for any clarification on this point.
СообщениеДобавлено: 12 мар 2013 21:41
Yes. Take and heat pad (cpu) on the tube. and look at the the heatsink temperature (cell). temperature should be identical throughout surface of the pipe
СообщениеДобавлено: 13 мар 2013 00:52
http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
СообщениеДобавлено: 17 мар 2013 20:52
May I replace tps51123A with tps 51125, the only difference I found in datasheet is pin18 named VCLK(frequency) in tps51125 and ENC in tps51123 ?
Thanks for any help.
СообщениеДобавлено: 17 мар 2013 21:10
hi "alexjustas" ! to make it clearer for me do you mean I heat the cpu pad bottom side and check the heat dissipation throughout heatsink ?
Thank you for any precision.
СообщениеДобавлено: 18 мар 2013 00:12
yes
СообщениеДобавлено: 19 мар 2013 01:37
yes
Ok "alexjustas", will try and see after replacement of tps51123 (new issue).
СообщениеДобавлено: 19 мар 2013 01:42
P.S Has any member used tps51125A as replacement for tps 51125 ?
Thanks for reply.
СообщениеДобавлено: 03 май 2013 16:03
Can anyone confirm that tps 51125 is replacement part for tps51123 ?
Please please help!!
Thanks
