Текущее время: 10 апр 2026 00:36
 Заголовок сообщения: Dell inspiron N7010 shut down after few hours of work
СообщениеДобавлено: 15 фев 2013 23:41
hi everyone !
I'm repairing a Dell inspiron N7010, with shut down issue after few hours of work, when powered with adapter, with or without battery.
When powered with battery only, no shut down !
I cleaned fan, applied new paste. Heat is normal, but always same problem.
Any suggestion should be appreciated.
Thanks
 Заголовок сообщения: Re: Dell inspiron N7010 shut down after few hours of work
СообщениеДобавлено: 16 фев 2013 05:40
Try to replace AC adapter. Its output voltage can become unstable because of overheating under the power load of laptop.
СообщениеДобавлено: 16 фев 2013 15:47
Good idea, will try new adapter and report soon.
May be I was far away thinking of Mobo Ac in section intermittent fail.
