Текущее время: 08 апр 2026 09:01
 Заголовок сообщения: HP DV5000 no display Platform COMPAL_LA-2771
СообщениеДобавлено: 11 май 2013 18:08
DV 5000 came dead. After changing one short cpu core fet : fds 6294. Lap fires up, with lights, fan, but no display.
Current reading stops at 0.7A with DDR and without DDR same. i guess no detection of DDR.
Found :
RAS and CAS at DDR slot measured 0.4V (low), sometimes floating to 0.79V and up to 1V.
VTT at net resistors, sometimes OV (fail), others 1.5V (normal).
I guess I have to reflow net resistors for VTT and Ati BGA RAS and CAS correct voltages ! Or any other suggestion is welcome ?
Also found :
at LVDS connector :
+LCDVDD = 0V (3V normal) consequence of ENVDD=0V issued from ATI RS480M_BGA706 to Q7 base
ENABLT = 0V instead of 2 to 3V issued from RS480M to KB910 consequence of INVT_PWM = 0V (output of KB910)
BKOFF = 0V
DAC_BRIG = 0V
DISPOFF#=0V
I will appreciate any urgent suggestion about next steps to be taken.
Thank you
see joined snapshots files.
LCD Panel & Inverter Connector.docx [582.34 КБ]
 Заголовок сообщения: Re: HP DV5000 no display Platform COMPAL_LA-2771
СообщениеДобавлено: 11 май 2013 18:16
New attachments : 3 files.
BLOCK DIAGRAM.docx [254.85 КБ]
ATi-Graphic controller.docx [288.5 КБ]
CPU-Memory control.docx [439.88 КБ]
Зарегистрированные пользователи: Google [Bot], Rustic, Yandex [Bot]
cron
