Текущее время: 16 май 2026 03:18
 Заголовок сообщения: 215-0674034 and compatible model 215-0674042?
СообщениеДобавлено: 16 июл 2013 16:16
Hi friends,
on the market was appear 215-0674042 as compatible model for 215-0674034, it is true? Look please:
http://www.ebay.com/itm/2011-BRAND-NEW- ... 2a2bccecd2
Anyone has experience with 215-0674042?
 Заголовок сообщения: Re: 215-0674034 and compatible model 215-0674042?
СообщениеДобавлено: 16 июл 2013 16:50
About the compatibility can only be judged on a particular platform, where you will be installing the chip
In most cases, replacement is correct, but it is necessary to check the experimental :)
СообщениеДобавлено: 17 июл 2013 12:29
Hi!
Contact seller for compatibility check. If seller guarantees this - buy. If chip not work on your system, you can require full refund (incorrect item description). Pay only with paypal and Paypal must be on your side in this situation.
With best wishes.
