Текущее время: 05 май 2026 05:36
 Заголовок сообщения: HP ProBook 4720s no power at all
СообщениеДобавлено: 30 июл 2013 12:21
hi folks,
we have here a HP Probook 4720s wich takes no power at all. We connect 19V to the board and no current is running into the board.
We've checked all fuses and didn't see any damage to the board.
Is there anybody out there who can help us find the problem with this board?
its an S_Intel M\B H9265_4 48 GK06 041
Thanks to all.
 Заголовок сообщения: Re: HP ProBook 4720s no power at all
СообщениеДобавлено: 30 июл 2013 15:12
Hello
If understood correctly, you are not charging the laptop. If so, then maybe you have your laptop out of service components are responsible for the definition of the input voltage (the average output to the power connector). Or problems with the unit, there is no voltage on the middle pin.
Best regards.
СообщениеДобавлено: 30 июл 2013 20:19
hey, ty for ur reply. we just checked all things from outside.
the current is coming from the jack to the board but gest lost on the board anywhere maybe u know which parts could cause this problem.
t
СообщениеДобавлено: 31 июл 2013 09:17
The options are:
1 - Power is lost immediately after the power connector on the motherboard to the input of the converter.
(possibly faulty fuse, a circuit interruption)
2 - Power disappears when the input of the converter. (maybe a problem with the chip converter itself or its Mosfet).
Or rather hard to say.
Best regards.
СообщениеДобавлено: 31 июл 2013 14:43
Hi all.
Thank you all for your replies,
I have no idea to check the converter, can you please tell me some points where should I measure what voltage?
СообщениеДобавлено: 31 июл 2013 14:55
http://imageshack.us/photo/my-images/94/yahr.jpg
СообщениеДобавлено: 01 авг 2013 12:39
hello
This image is not visible marking Mosfet. Make a clearer picture. Furthermore, an input transducer located on the other side of the board. It is advisable to make his picture.
Best regards..
