Текущее время: 14 май 2026 18:15
 Заголовок сообщения: dell vostro 2520 some times working dv15 mlk mb 11280-1 pwb:
СообщениеДобавлено: 23 ноя 2013 22:20
dell vostro 2520 some times working dv15 mlk mb 11280-1 pwb:mxrd2 rev:a00
 Заголовок сообщения: Re: dell vostro 2520 some times working dv15 mlk mb 11280-1
СообщениеДобавлено: 23 ноя 2013 23:06
So what`s the problem ?
СообщениеДобавлено: 24 ноя 2013 11:21
the fault does not trigger some times trrigger
СообщениеДобавлено: 24 ноя 2013 11:59
Knob?
СообщениеДобавлено: 24 ноя 2013 20:49
knob????
СообщениеДобавлено: 24 ноя 2013 21:25
trigger????
СообщениеДобавлено: 24 ноя 2013 23:27
switch
СообщениеДобавлено: 24 ноя 2013 23:43
So check the switch.
And let me give you a good advice. As the call so the echo.
If you want to get a good answer - be so kind tell us all about the problem.
Is it fair enough ?
СообщениеДобавлено: 28 ноя 2013 18:25
no switch problm switch working properly but cannot power on
СообщениеДобавлено: 29 ноя 2013 06:38
Give us complete information about the problem.
Did you sew the bios? Did you check or change the cmos battery?
Did you check all powers? Etc.
СообщениеДобавлено: 30 ноя 2013 14:04
put dc jack system automatically power ON working properly.
all power is ok.
but the problem is system turn off and cannot ON.
3-4hrs after system working (automatically power ON)
СообщениеДобавлено: 30 ноя 2013 17:39
OK, but why you so insistive that the switch is working good?
Don`t you think that the switch could have not good contact ?
Did you replace it with normal one?
СообщениеДобавлено: 30 ноя 2013 22:18
without working amphere 0.020
СообщениеДобавлено: 01 дек 2013 07:59
Is it suspicious? Its normal cos the the board has a standby mode when the small part of the board is still working.
DID YOU REPLACE THE SWITCH WITH NEW ONE???
