Текущее время: 15 мар 2026 20:59
 Заголовок сообщения: hp 630 thermal shutdown
СообщениеДобавлено: 31 янв 2014 17:58
i face a problem with hp630 laptop motherboard that as the display comes fan rotates very fast and the board shutdown please help
 Заголовок сообщения: Re: hp 630 thermal shutdown
СообщениеДобавлено: 31 янв 2014 18:17
need repair
СообщениеДобавлено: 31 янв 2014 19:44
shutdown is thermal protect cpu or gpu. Replace thermal grease :-ok-:
СообщениеДобавлено: 01 фев 2014 17:12
i had already changed the thermal grease and heat sink. i had noticed that cpu does not get too hot as the motherboard shut off. i had already replace the cpu. i had programmed the bios dump from a working board. but nothing works.
СообщениеДобавлено: 02 фев 2014 22:52
You're lying, or you have a problem with your laptop on iron, then follow the rules of this forum...
Зарегистрированные пользователи: Google [Bot], Xlebushek, Yandex [Bot]
