Текущее время: 26 май 2026 13:29
 Заголовок сообщения: Dell Inspiron N5010 - no response on power
СообщениеДобавлено: 06 окт 2013 10:24
hello.
Dell N5010 intel Motherboard 48.4HH01.011 DG15 MB Laptop unless the overvoltage, the additional plate with pins in the power socket is damaged Realtek, unless the network. The whole plate is swapped for another, efficient. Motherboard does not respond to power, not charging the battery. disc at rest with the processor and memory takes 150 mA. 51125 Very heats up, marked PU4601. I would be a bit pattern of the system.
Thank you...
Зарегистрированные пользователи: салага, Google [Bot], Yandex [Bot]
