Текущее время: 25 май 2026 21:03
 Заголовок сообщения: Описание пост карты
СообщениеДобавлено: 01 фев 2009 08:40
Ver 5.1 Mini PCI / Mini PCI-E / LPC Combo-POST CODE -Card
This notebook Combo-POST CODE-Card supports three bus
interfaces: MINI PCI, Mini PCI-E and LPC. For using this
Combo-POST CODE-Card, one interface needs to be connected only,
and please ensure other two interfaces unconnected. This product is
user friendly, and is designed with good stability. It is an ideal tool for
notebook repairing.
_ . Combo-POST CODE-Card structure and usage
_ . The Mini-PCI interface in the Combo-POST CODE-Card
_ . The Mini PCI-E interface in the Combo-POST CODE-Card
_ . The LPC interface in the Combo-POST CODE-Card
_ . The LED-Display in the Combo-POST CODE-Card
_ . Part of Error-Code explanation
1. Combo-POST CODE-Card structure and usage
.. Mini-PCI interface:
This is used to connect this Combo-POST CODE-Card to notebook’s
Mini-PCI slot.
.. Mini-PCIE interface:
Mini-PCIE slot.
.. LPC interface:
LPC connector.
.. ASIC:
.. Two 7-segment LEDs:
This is used to display the Error-code and RST/CLK signals.
..Test port: This port is reserved, and end-user should not use this
port.
2. The Mini-PCI interface in the Combo-POST CODE-Card
Mini PCI is a general interface used in notebook. It includes 124 pins.
This Combo-POST CODE-Card doesn’t fully use those pins, and only
101 pins are used. When installing this Combo-POST CODE-Card to
your notebook main-board, you will find the Combo-POST
CODE-Card is shorter than the notebook Mini-PCI slot. This is correct,
and it serves better for you to plug or unplug this Combo-POST
CODE-Card.
3. The Mini-PCIE interface in the Combo-POST CODE-Card
Mini-PCIE is used as a trend in the new notebooks. Compared with
Mini-PCI, Mini-PCIE occupies less space. This Combo-POST
CODE-Card doesn’t use all of the Mini-PCIE bus pins. And only the
below pins are used: PIN-8, PIN-10, PIN-12, PIN-14, PIN-16, PIN-17,
and
PIN-19. In the Mini-PCIE spec, those pins are reserved, and it is not
standard, so some of Notebook manufacturers define it as a LPC
POST CODE-port. And more and more notebook manufacturers are
using this standard, such as IBM, Toshiba, HP, ASUS, TCL and
etc…This Combo-POST CODE-Card can only work in the notebooks,
which are with the LPC POST CODE-port definition. For the
notebooks don’t support this LPC POST CODE-port definition, this
Combo-POST CODE-card PCI-E interface will not work.
Note: Please be aware that Mini-PCIE is supported with limitation, and
it can works in most of notebooks, but not all.
4. The LPC interface in the Combo-POST CODE-Card
For users whose notebooks don’t support the Mini-PCI interface and
the Mini-PCIE interface, you can use the third port: LPC interface.
LPC interface exists in all notebooks’ main-boards. In the
Combo-POST CODE-Card, from left to right, the LPC definition is:
PIN1-3.3V, PIN2-LFRAME#, PIN3-LAD3, PIN4-LAD2 PIN5-LAD1
PIN6-LAD0, PIN7-GND PIN8-LRESET# PIN9-LCLK PIN10-3.3V.
Usually, the notebook boards haven’t LPC connectors or slots. And
users will need to connect this LPC port to the notebook by using
wires. Below is some description for how to connect the Combo-POST
CODE-Card to your notebook through this LPC interface.
If your notebooks use LPC VBIOS, you can connect the
Combo-POST CODE-Card to your notebook’s VBIOS bus.
LPC VBIOS Pin definition:
PIN2-RST# PIN13-LAD0
PIN14-LAD1 PIN15-LAD2
PIN16-GND PIN17-LAD3
PIN23-LFRAME# PIN25-VCC
PIN31-CLK
The connection between Combo-POST CODE-Card and the
notebook’s main-board.
Combo-POST CODE-Card Notebook VBIOS
PIN1-3.3V PIN25-VCC
PIN2-LFRAME# PIN23-LFRAME#
PIN3-LAD3 PIN17-LAD3
PIN4-LAD2 PIN15-LAD2
PIN5-LAD1 PIN14-LAD1
PIN6-LAD0 PIN13-LAD0
PIN7-GND PIN16-GND
PIN8-LRESET# PIN2-RST#
PIN9-LCLK PIN31-CLK
PIN10-3.3V PIN25-VCC
You can connect this Combo-POST CODE-Card to any LPC bus.
Some LPC interface chips are listed as below. You can connect the
Combo-POST CODE-Card to the corresponding pins. For more
information, please refer those chips’ datasheets.
Note: This Combo-POST CODE-Card uses 3.3V as power supply,
and you can use any 3V3 and GND signals in your notebook
main-board. Please be aware that connecting the Combo-POST
CODE-Card to a non-3.3V power may damage this Combo-POST
CODE-Card.
For IBM X 60 notebooks, the LPC interfaces are located in the U39
slot of the main-board. The Pin definitions are as below:
A2->LRESET# A3->LFRAME#
A5->LCLK A9->LAD3
A10->LAD2 A11->LAD1
A12->LAD0
For IBM T6 R6 notebooks, the LPC interfaces are located in the J26
A1->LCLK A3->LFRAME#
B2->LRESET# B7->LAD3
A7->LAD2 B6->LAD1 A6->LAD0
5. The LCD-Display in the Combo-POST CODE-Card
The Display portion is composed with two 7-segment LEDs. The two
“Dots” of the LEDs are used to indicate the notebook “RST” and “CLK”
status. The left side “Dot” is for “RST”, and the right side “Dot” is for
“CLK”. When the notebook is in “Reset” status, the left side “Dot” will
be lighted. And when the notebook has a correct CLK output, the right
side “Dot” will be lighted. When you hold on the notebook’s “RESET”
button, the left side LED “Dot” will be lighted, and the right side LED
“Dot” will be off. When you release the notebook “RESET” button, the
left side LED “Dot” will be off, and the right side LED “Dot” will be
lighted. Then the two LEDs will show the corresponding POST CODE
code. If the left side LED “Dot” is always on, it means your notebook
main-board has “RESET” problem.
6. Part of Error-Code explanation
When the notebooks are running, this Combo-POST CODE-Card will
show the corresponding POST CODE code. If there is a problem in
the notebook, you can judge the problem by the POST CODE code.
Below is the explanation for some main error codes.
AWARD BIOS:
The explanation when the Combo-POST CODE-Card shows the
below POST CODE codes.
Code Explanation Note
C0 Close Cache
01 Processor Test
07 CMOS Test
C1 Memory Size Test
0A Set the Interrupt Table
0C Initiate the Keyboard
0D Initiate the Graphic Card
1A Show CPU Frequency
3C CMOS Setting
42 Initiate Hardware
52 Test the Extended ROM
FF Boot
AMI BIOS:
00 Error in Self Test
01 Error in Processor Test
0D,0F Error in CMOS Test
1A to 22 Error in Memory Test
3A Error in Graphic Card
FF Pass the self Test
Remark: For the POST Code explanation in detail, please check with
the bios brand and version, then can be found on website. If you need
our assistance, please feel free to contact with us,
info@winter-con.com
СообщениеДобавлено: 01 фев 2009 12:14
это к чему? Во всяком случае не в том разделе...
СообщениеДобавлено: 01 фев 2009 13:46
OFFTOP-е были жалобы на отсутствие описания.
