Текущее время: 05 май 2026 11:59
 Заголовок сообщения: HP dv7-3015ew - turns off after a second
СообщениеДобавлено: 06 окт 2013 10:13
Hello,
laptop as a topic DAUT1AMB6E0 plate REV. E. laptop starts, but then stops. Consumption (plate armed with RAM, CPU) in stby about 0,010 A, turning jumps to 0.9 ~ 1.4 A and off. Measurements of the coils: PL13 - 3, 39V (1044 ohms) PL12 - 5.14 V (1300 Ohm) PL5 - 0.67 V (resistance out of range) PL6 - 0V (after 1.8 V), 497 Ohm PL9 - 0V (after 1V), 13 ohms (without CPU resistance of about 1300 ohms) PL8 - 0V (after 1V), 13 ohms (CPU resistance of about 1300 ohms) PL7 - 0V (after 1.25 V), 210 Ohm PL14 - 0V (after 1.12 V), 6 Ohm I do not have the CPU to substitution.
Thank you for all replays ....
 Заголовок сообщения: Re: HP dv7-3015ew - turns off after a second
СообщениеДобавлено: 06 окт 2013 10:23
PQ41
Зарегистрированные пользователи: elf22, Google [Bot], Yandex [Bot], Фильшин Сергей
