Текущее время: 26 май 2026 21:24
 Заголовок сообщения: Google translate and this forum
СообщениеДобавлено: 06 сен 2011 17:30
Hi, Admins.
Google Translate (GT) is not able to translate many of the special characters on this forum. For foreign users (like me) it's very difficult to understand some posts.
I have noticed that you have a content language meta tag set to British English:
Код:
<meta http-equiv="content-language" content="en-gb" />
Maybe we can get better results from GT if you change it to:
Код:
<meta http-equiv="content-language" content="ru" />
Just a thought.
 Заголовок сообщения: Re: Google translate and this forum
СообщениеДобавлено: 06 сен 2011 18:35
all working well !
http://translate.google.com/translate?h ... Findex.php
и даже на японском работает !!!
СообщениеДобавлено: 06 сен 2011 18:53
Would you like provide links to topics with the "special characters", uncorrectly translated?
у меня нет подписи
СообщениеДобавлено: 07 сен 2011 03:28
One example:
Another:
СообщениеДобавлено: 07 сен 2011 21:47
ablacon64 писал(а):
Hi, Admins.
Код:
Код:
Just a thought.
Hi, apparently problem is GT don't have proper Russian-Portuguese dictionary
and simply transliterated unknown words. Adding meta tags doesn't help you with this issue. You may use Russian-English for better results.
СообщениеДобавлено: 08 сен 2011 00:02
как то не вьехал.у нас как бы русско язычный форум. :a_g_a:
СообщениеДобавлено: 08 сен 2011 01:55
Try using a different browser. To translate Chinese websites now, I have better results with Google Chrome. I think not all browsers can correctly capture or send the collected data from page to translate.
СообщениеДобавлено: 08 сен 2011 04:55
I'll try google chrome. Sometimes I can't understand the context, translation is very bad.
СообщениеДобавлено: 13 сен 2011 20:00
Test it http://www.online-translator.com/Defaul ... rmtlang=en
СообщениеДобавлено: 14 сен 2011 07:06
User74(Сергей Попов) писал(а):
Thank you. It worked fine.
The reason I use GT is because I can translate a page on the fly (instantly) but that will do for now. Thanks!
