Текущее время: 24 апр 2026 06:44
 Заголовок сообщения: как отсюда вытащить дамп.
СообщениеДобавлено: 29 май 2013 16:03
http://h10025.www1.hp.com/ewfrf/wc/soft ... 3935#N1042 вот отсюда :)
 Заголовок сообщения: Re: как отсюда вытащить дамп.
СообщениеДобавлено: 29 май 2013 16:10
скачать єкзешник, открЫть винраром, скопировать в папку.
потмо запустить полученный экзешник с ключем хелпа
D:\111\sp47135\308F0F19.exe /?
итого:
| AMI Firmware Update Utility v4.39_HP |
| Copyright (C)2009 American Megatrends Inc. All Rights Reserved. |
| Usage: AFUWIN <ROM File Name> [Option 1] [Option 2]... |
| or |
| AFUWIN <Input or Output File Name> <Command> |
| or |
| AFUWIN <Command> |
| Commands: |
| /O - Save current BIOS into file |
| /C - Refer to Options: /C |
| /U - Display ROM file's ROMID |
| /S - Refer to Options: /S |
| /Ln - Refer to Options: /Ln |
| /M - Refer to Options: /M |
| /MAI - Disaply System ROM and ROM file's MA information |
| /HOLE: - Update specific ROM Hole according to given name. |
| NewRomHole1.BIN /HOLE:RomH1 |
| /HOLEOUT: - Save specific ROM Hole according to given name. |
| NewRomHole1.BIN /HOLEOUT:RomH1 |
| /NCB: - Update specific Non-Critical Block according to given name. |
| NewNcb1.BIN /NCB:Ncb1 |
| /NCBOUT: - Save specific Non-Critical Block according to given name. |
| NewNcb1.BIN /NCBOUT:Ncb1 |
| /D - Verification test of given ROM File without flashing BIOS. |
| /CLNEVNLOG - Refer to Options: /CLNEVNLOG |
| Options: |
| /P - Program main BIOS image |
| /B - Program Boot Block |
| /N - Program NVRAM |
| /C - Destroy CMOS checksum |
| /E - Program Embedded Controller Block |
| /K - Program all non-critical blocks |
| /Kn - Program n'th non-critical block only(n=0-7) |
| /Q - Silent execution |
| /REBOOT - Reboot after programming |
| /X - Don't Check ROM ID |
| /S - Display current system's ROMID |
| /Ln - Load CMOS defaults:(n=0-3) |
| L0: Load current optimal |
| L1: Load current failsafe |
| L2: Load optimal from ROM file |
| L3: Load failsafe from ROM file |
| /M - Update bootblock MAC address if it exists |
| Example: /M1234ABCD will update MAC to 1234ABCD |
| /R - Preserve ALL SMBIOS structure during NVRAM programming |
| /ECUF - Update EC BIOS when newer version is detected. |
| /SHUTDOWN - Shutdown after programming. |
| /EC - Program Embedded Controller Block. (Flash Type) |
| /CLNEVNLOG - Clear Event Log. |
СообщениеДобавлено: 29 май 2013 16:23
ничего не понял :(
СообщениеДобавлено: 29 май 2013 16:53
тема продолжается.поставил какой то биос с форума.ноут включается но пишет,что фая не его и в биос зайти не может.так как вытянуть дамп?
СообщениеДобавлено: 29 май 2013 17:46
зашибись на форуме перевелись мастера которые бинарник могут вытащить :-)
СообщениеДобавлено: 29 май 2013 17:54
А тему почитать как вытащить??
Этоже ами
--== Михаил Перекрестов ==--
СообщениеДобавлено: 29 май 2013 17:55
viewtopic.php?f=186&t=9505&p=459711#p459711
СообщениеДобавлено: 29 май 2013 17:56
Сергей Петрович писал(а):
зашибись на форуме
....это зашей...
Вложение:
Mini 110-1031NR_F19.rar
СообщениеДобавлено: 29 май 2013 17:57
...так таж ветка в :) клубе...
СообщениеДобавлено: 29 май 2013 18:00
вот за что я уважаю дядьмиша пришёл и всё сделал,а то некоторые начинают умничать и левые ссылки давать. :-)
СообщениеДобавлено: 29 май 2013 18:01
дядьмиша
так у меня модель немного другая или пох? :du_ma_et:
Вы не авторизованы для чтения этого форума.
СообщениеДобавлено: 29 май 2013 18:06
дядьмиша
... :) ..льстишь...
..у них биосы одинаковые..308F0F19...шей.. не ssы.. :)
шью :ya_hoo_oo:
СообщениеДобавлено: 29 май 2013 18:07
Нет там по ссылке ничего, надо вводить серийный номер для поиска. У меня семерка. Делаю так: скачаное приложение с расширением ехе (например sp51459) запускаю и дальше ставим галочку, что согласны с лицензией, смотрим в куда он распаковывается (на диск С, в папку SwSetup). В конце распаковки, смотря какой ехешник, может предложить создать загузочную флешь или СД, или обновить из под винды. Закрываешь приложение. Открываешь на диске С папку SwSetup и смотришь, что там есть.
СообщениеДобавлено: 29 май 2013 18:11
А в ЛС трудно посмотреть??
Что Петрович не в клубе заметил только после отправки - поэтом ЛС
Последний раз редактировалось Mikkey 29 май 2013 18:13, всего редактировалось 1 раз.
СообщениеДобавлено: 29 май 2013 18:12
посмотрел.ничего не понял. :sh_ok:
СообщениеДобавлено: 29 май 2013 18:13
нах.тема закрыта.спасибодядьмиша за оперативную помощь.всё пучком. :ya_hoo_oo:
СообщениеДобавлено: 29 май 2013 18:15
Тогда это тяжёлый случай - так и будете в слещий раз клянчить прошивы, вместо самостоятельного выдирания... :-)
P.P. Забить в яндекс - и первая ссылка Ваша :)
СообщениеДобавлено: 29 май 2013 18:20
я могу и поклянчить тем более у меня ничего не отвалится,но и яндекс почитаю.один плюс в клянчивание,что потом не надо сидеть и пыхтеть вписывая в биос регномер. :a_g_a:
СообщениеДобавлено: 29 май 2013 18:25
Mikkey
а понял,это название програмки которая биос вытаскивает.так?так надо было и сказать,что это программка,а то дал какое то название потом сиди и думай куда это привинтить.спасибо. :a_g_a:
СообщениеДобавлено: 29 май 2013 18:33
Ну я хз, по-моему и так всё понятно, а если непонятно -- опять таки яндекс... :)
Зарегистрированные пользователи: Google [Bot], rzdpasha, Yandex [Bot]
cron
