Текущее время: 26 май 2026 19:07
 Заголовок сообщения: Ошибка при установке системы
СообщениеДобавлено: 26 июн 2015 21:41
При установке сразу выскакивает ошибка "При подготовке к установке произошла ошибка. Попробуйте повторить запуск этой программы."
[spoiler2=журнал установщика]Dec 31 16:18:09 localhost Unknown[293]: 2000-12-31 16:18:09.496 Install OS X Mountain Lion[327:707] NSSoftLinking - The Librarian framework's library couldn't be loaded from (null).
Dec 31 16:18:09 localhost Unknown[293]: 2000-12-31 16:18:09.497 Install OS X Mountain Lion[327:707] NSSoftLinking - The function 'LBCurrentProcessHasUbiquityContainer' can't be found in the Librarian framework.
Dec 31 16:18:09 localhost Unknown[293]: objc[327]: Class IFJS_Context is implemented in both /System/Library/PrivateFrameworks/Install.framework/Frameworks/DistributionKit.framework/Versions/A/DistributionKit and /System/Library/PrivateFrameworks/Install.framework/Versions/A/Install. One of the two will be used. Which one is undefined.
Dec 31 16:18:09 localhost Unknown[293]: objc[327]: Class IFJS_Cache is implemented in both /System/Library/PrivateFrameworks/Install.framework/Frameworks/DistributionKit.framework/Versions/A/DistributionKit and /System/Library/PrivateFrameworks/Install.framework/Versions/A/Install. One of the two will be used. Which one is undefined.
Dec 31 16:18:09 localhost Unknown[293]: objc[327]: Class PKGraphicsHardwareRequirements is implemented in both /System/Library/PrivateFrameworks/Install.framework/Frameworks/DistributionKit.framework/Versions/A/DistributionKit and /System/Library/PrivateFrameworks/Install.framework/Versions/A/Install. One of the two will be used. Which one is undefined.
Dec 31 16:18:09 localhost Unknown[293]: objc[327]: Class PKRequiredGLRenderer is implemented in both /System/Library/PrivateFrameworks/Install.framework/Frameworks/DistributionKit.framework/Versions/A/DistributionKit and /System/Library/PrivateFrameworks/Install.framework/Versions/A/Install. One of the two will be used. Which one is undefined.
Dec 31 16:18:09 localhost Unknown[293]: objc[327]: Class PKRequiredCLDevice is implemented in both /System/Library/PrivateFrameworks/Install.framework/Frameworks/DistributionKit.framework/Versions/A/DistributionKit and /System/Library/PrivateFrameworks/Install.framework/Versions/A/Install. One of the two will be used. Which one is undefined.
Dec 31 16:18:09 localhost Unknown[293]: objc[327]: Class PKFolderArchiveSignature is implemented in both /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/PackageKit and /Install OS X Mountain Lion.app/Contents/PlugIns/IA.bundle/Contents/MacOS/IA. One of the two will be used. Which one is undefined.[/spoiler2]
Что было сделано:
Нет разницы делать рекавери через интернет или ставить разные версии с юсб флешки, тоже ошибки.
Не дает форматировать диск в дисковой утилите. Не получается восстановиться через time machine.
Система ставится и исправно работает на внешнем жестком диске, но при подключении через сата висит на яблоке. Тут я подумал на железо, в частности шлейф жесткого диска, но система без проблем установилась на 2й жесткий диск. Логично проблема в 1м жестком диске, но при попытке установить на 3й, 4й диск те же ошибки что и при 1м. И тут я зашел в тупик, выручайте :ny_tik:
