Текущее время: 26 май 2026 14:13
 Заголовок сообщения: a1278 k24 map no 12.58volts
СообщениеДобавлено: 10 ноя 2016 23:55
hi all,
I been stuck on this map for a while now K24 a1278. i get 12.58volts momentarily and gradually drops to 2volts.The magsafe lite remains green but no voltage.i have CHANGED several isl6258a also the current sensing resistor and cap changed still same problem.earlier i got an open track from the shunt resistor to chagr_csip i repaired the track still the voyage comes for a 2 sec and goes back to zero.I have disconnect the F7000 fuse to the main system ppbus_g3h but still the voltage comes for 2 sec and drops slowly.pls can any one tell me the prob changed almost all cap and resistor mosfet
 Заголовок сообщения: Re: a1278 k24 map no 12.58volts
СообщениеДобавлено: 28 дек 2016 01:18
Did u manage to solve your problem? Have same issue. Changed 3 isl but still MOSFET is not opening..
