Текущее время: 26 май 2026 13:29
 Заголовок сообщения: a1502 820-4929 trakpad and keyboard
СообщениеДобавлено: 13 июл 2018 23:06
hello
i have a a1502 the trackpad and keyboard does not work i have tpad_3.3v_s4 and also 3.42v.i dont see any corrosion on the board what should i look for . also i put another keyboard still same problem.i believe there is a firmware rom in the trakpad which enables keyboard so if the trackpad is bad the keyboard also does not work.
 Заголовок сообщения: Re: a1502 820-4929 trakpad and keyboard
СообщениеДобавлено: 16 июл 2018 16:18
820-4929 ??
:a_g_a:
Check the cable and data buses between the MB and the trackpad, smbus - spi
The fish will soon be caught that nibbles at every bait...)
СообщениеДобавлено: 19 июл 2018 12:40
a1502 820-4929 trakpad and keyboard Can I use it?
СообщениеДобавлено: 30 июл 2018 21:21
hi the problem was the trackpad works on i2c the eeprom on the trackpad was bad but i used a new trackpad now works fine .thanks case closed
Зарегистрированные пользователи: салага, Google [Bot], Yandex [Bot]
